Activity › Forums › Apple Final Cut Pro Legacy › frame Blending
frame Blending
Posted by Eron Otcasek on April 30, 2010 at 6:47 pmHi all….
I would love it if anyone has found a way to have FCP turn off frame blending as the default for speed changes… or at least invented a keyboard shortcut!could save me hours..
thanksStan Ve replied 12 years, 6 months ago 9 Members · 12 Replies -
Jeremy Garchow
April 30, 2010 at 7:09 pmWhen hitting command-j to change speed, simply turn it off?
Jeffrey Di lullo
May 1, 2010 at 4:26 pmYou can change your sequence settings, Command + 0 or Sequence>Settings>Render Control Tab. Un-check Frame Blending for Speed. This should effect your entire sequence.
Jeffrey Di Lullo
Jeffedits.com -
Eron Otcasek
May 1, 2010 at 4:53 pmThat sounds very promising. Thank you!!! I was beginning to think I would be the but end of a few jokes for the rest of my life!
Nate Tam
May 28, 2010 at 8:42 amChanging the settings in preferences doesn’t work for speed changes in the timeline. It only works for rendering.
I think what he’s asking is to have the checkbox unchecked as a default when you hit command-j.
Even though it doesn’t seem like something you should be complaining about, for me I somehow end up cutting music videos that have a TON of speed changes and don’t want frame blending…In that case, its just really annoying to be changing it every cut.
Tom Small
November 17, 2010 at 12:37 amHas anyone found a solve yet? I’m searching for the same thing. I would much rather be able to turn it on when I wanted, not be forced to turn it off each time.
TomTom
Rafael Amador
October 18, 2011 at 11:07 amIn FC main menu there is an option to “Provide Final Cut feed back”.
You can contact Apple.
They are the one can give a solution.
If was a workaround would have been posted here.
If you don’t like when people try to deal with FCs shortcomings with a bit of humor, sorry.
We are not Apple.
Enough that people spend their free time trying to help others.
rafael
