Activity Forums Blackmagic Design frame accurate edit to tape with M2000P?
  • frame accurate edit to tape with M2000P?
    Posted by Sean Davison on July 13, 2006 at 1:36 pm
    OK so whats the trick – Ive got the M2000p set to lock to incoming video (the only way it will work) and its hit and miss as to the frame accuracy of the layback. I have to set the frame offset to 5 or six frames depending on the mood of the Card. I used to have this problem with my Cinewave – it was a reference problem from the deck but I can only get my HDW M2000p to lock to the incoming HDSDI signal (using embedded audio too)
    Its a bit irritating when you are trying to lay off a 50 minute seamless programme and you go bacck to find out its layed off at 10 00 01!
    Sean Davison replied 20 years, 2 months ago 1 Member · 1 Reply
  • Sean Davison
    July 13, 2006 at 1:38 pm
    sorry Im using osx 10.4.5 – latest drivers and latest FCP
