Activity › Forums › Apple Final Cut Pro Legacy › Fragmented files after export.
Posted by Valerie Marinho on May 2, 2014 at 4:53 pmHi everybody,
My problem : on FC7, the quicktime export to create my master is fragmented in one .mov and several -av (?), each 4.1 Go. (My Hard Drive is not in fat32). And the .mov can be read only for 5 mns (my film is about 70mns).
Can anyone has a solution ?
Thanks in advance,
Valerie
Valerie Marinho replied 12 years, 4 months ago 2 Members · 7 Replies -
Shane Ross
May 2, 2014 at 5:05 pmHow is the drive formatted, if not Fat32? How did you export? File>Export>Quicktime Movie? Self contained…other settings?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Valerie Marinho
May 2, 2014 at 5:23 pmThanks for your answer,
The external hard drive is formated in mac Os extended.
The export : file-export-quicktime sequence. No conversion, i want to have a master via quicktime, not a compressed file.
Other settings, the quicktime export is set on apple pro res 422 (hq)
Excuse my bad english, i’m in Paris, France …
Shane Ross
May 2, 2014 at 6:05 pmIs this drive also set up as your Capture Scratch drive? In the Final Cut Pro System Settings…in the SCRATCH DISKS tab….at the bottom. Do you have CAPTURE LIMIT/FILE EXPORT size checked? And is it set to 4000 or so MB?
Shane
Little Frog Post
Valerie Marinho
May 2, 2014 at 6:43 pmYes, it is the same drive and the Scratc setting is notched on 4000 MB.
Do i un notch it ? -
Shane Ross
May 2, 2014 at 7:32 pm -
Valerie Marinho
May 2, 2014 at 7:51 pmOk, thanks Shane,
I do that and make another export right away.
I cross my fingers and i’ll let you know after the export !
Thanks again -
Valerie Marinho
May 2, 2014 at 9:46 pmThanks Shane,
I did un notch the CAPTURE LIMIT/FILE EXPORT and my export is just perfect and in one piece !
Thanks again
