Activity Forums Maxon Cinema 4D Fracture object and GI problem
  • Fracture object and GI problem
    Posted by Corrado Carlevaro on September 2, 2009 at 8:24 am
    as I put an extruded text in the Fracture object and explode and connect the segments to animate the letters with effectors, when I render it with GI (full animation settings), the text is all “stained” with flickering stains. I suppose it’s a GI problem because when i render a single frame it looks ok, and the “stains” look pretty much the “stains” you get when you load a GI cached file for a scene that in the meanwhile has been slightly changed. Hope it’s clear. Any idea?
    Thanks in advance
    cervelo
    Corrado Carlevaro replied 16 years, 10 months ago 2 Members · 2 Replies
  • Eric Sanderson
    October 28, 2009 at 1:42 pm
    Hey im having the exact same problem with the exact same effect…did you ever get an answer or figure out how to fix it?
  • Corrado Carlevaro
    November 1, 2009 at 9:43 am
    Sorry, i didn’t… I think it’s a GI problem, so you have to choose a different render engine, or not using GI, or not using fracture
