Activity › Forums › Adobe After Effects › Fractal Ocean
  • Fractal Ocean
    Posted by Scottt on October 1, 2005 at 7:14 am
    Hi, I’m using AE 5.5, and I need to create an animated ocean surface. Does anyone know how to do this, perhaps using the Fractal effect?
    Scott
    Scottt replied 20 years, 12 months ago 3 Members · 3 Replies
  • Chris Smith
    October 1, 2005 at 2:34 pm
    Ideally you woud use the plug-in ‘psunami’ or create the surface in true 3D. But somewhere I saw a bump map plug-in for AE. It may be worth a shot. That way you could pipe in the fractal noise to the bump map effect and get somewhat of a look. But bump mapping won’t get you the swells (geometry is better for that) but for riples and other surface features, bump mapping is good.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Andrew Kramer
    October 1, 2005 at 5:41 pm
    Here I made this, Its certainly not as good as psunami but it may work.
    play around with the evolution options of the fractal noise.
    http://www.VideoCopilot.net/ocean.aep
    Andrew
  • Scottt
    October 4, 2005 at 7:02 am
    Thanks guys, I really appreciate it! I want to get Psumani, Knolls Light Factory and all the rest, unfortunately, budget restricts me. Even though I work in TV, motion graphics is primarily a hobby that -maybe- one day I’ll get to do professionally.
    Thanks again,
    Scott
