Activity Forums Adobe After Effects Fractal noise to displace position of layer
  • Fractal noise to displace position of layer
    Posted by Joe Burke on January 18, 2021 at 7:33 pm
    Hi all,
    I am attempting to affect the position of a layer based on a layer of fractal noise. The layer is keyframed to move and I want it to be affected by the fractal field, much like particles in particular.
    Is something like this possible? and how might I go about achieving this?
    I attempted to use Displacement Map, however, it effects the look of the layer by warping it.
    Filip Vandueren replied 5 years, 7 months ago 2 Members · 3 Replies
  • Filip Vandueren
    January 19, 2021 at 12:26 pm
    Check this tutorial based on one of Dan’s expressions:
    https://www.youtube.com/watch?v=1UaZNcVobhg&feature=youtu.be
  • Joe Burke
    January 20, 2021 at 5:14 pm
    Thank you for sending me this information.
    I am little stuck, not sure if you can shed some light not this.
    I have a layer (which is a flower) with 2 position key frames, moving the flower from left to right.
    I am applying this expression to the Anchor Point to move the flower based on a fractal noise layer, as it moves across the composition.
    x = thisComp.layer(“Gradient”).sampleImage(transform.position, [2,2]/2, true, time);
    however, this is kicking back an error “expression result must be of dimension 2, not 4”
  • Filip Vandueren
    January 20, 2021 at 6:20 pm
    Yes, you’re sampling the image and that gives 4 values in an array [r, g, b, a]
    Position needs 2: [x,y].
    So you’ll have to do some kind of calculation on the color to translate it into a position-value.
    For example add this final line:
    [x[0], x[1]]*20;
    And it will use red and green (0th and 1st element of x] with white moving 20px, black zero…
