Activity Forums Adobe After Effects fractal noise loop too fast
  • fractal noise loop too fast
    Posted by Emily Scollon on August 31, 2011 at 7:51 pm
    Hi there. I’m creating a fractal noise loop, and have it looping seamlessly, but in order to do so it needs to do a full revolution. Unfortunately this is too much movement for the 5 seconds i want it to animate. (Ideally it would only go to about 90 degrees) Any thoughts on how to do this within my 5 second animation? (obviously making it a 10 second animation would slow it down, but i need it to be 5 😉
    Walter Soyka replied 15 years ago 3 Members · 2 Replies
  • Joseph W. bourke
    August 31, 2011 at 9:20 pm
    You can do what is called a “dissolve loop”. I believe that there is even a script which will automatically create one for you – yup, there is:
    https://aescripts.com/the-loopmaker/
    To do it from scratch, you take the video which you want to loop, split it in the middle, swap the start half with the end half, and then put a dissolve in the middle (as long as you need it to not look distracting).
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Walter Soyka
    August 31, 2011 at 9:31 pm
    [Joseph W. Bourke] “You can do what is called a “dissolve loop”.”
    If you can’t solve it, dissolve it!
    Another option might be to use a particle system to replace your fractal noise effect (which may be very easy, very difficult, or somewhere in between, depending on the look you’re going for), and then follow Aharon Rabinowitz’s Creating a looping particle system tutorial [link].
    Walter Soyka
