Activity Forums Adobe After Effects Fractal Noise + Displacement Map not Working?
  • Walter Soyka
    September 20, 2016 at 4:08 pm
    When you precompose the Fractal Noise comp, make sure you use “Move all attributes into the new composition” so that the Fractal Noise effect stays on the solid layer and moves into the precomp. If you “Leave all attributes” instead, the solid will be precomposed but the Fractal Noise effect will remain in the main comp and apply to the precomp layer, and thus be invisible to the Displacement Map effect.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Tobias Aleksander moen
    September 20, 2016 at 4:26 pm
    Thank you so much!
    Did not even think about that 🙂
