Activity Forums Apple Final Cut Pro Legacy FPV to tape?
  • Posted by Phil Giriodi on October 25, 2009 at 7:05 pm
    My system is: Mac Intel, Max RAM, many HDs, OS 10.5.6, FCP 5.1.4
    I am able to capture HDV into FCP, however, when I attempt to ‘print-to-tape’ my deck will not capture. My HDV deck is a Sony 1080i, HVR M-1OU.
    Print-to-tape works fine in the SD mode but not the HDV. I’ve tried every setup combination that I can think of.
    Your assistance would be greatly appreciated.
    Thanks in advance.
    Jerry Alto replied 16 years, 10 months ago 4 Members · 5 Replies
  • Michael Gissing
    October 25, 2009 at 9:15 pm
    Vers 5.1.4 was early days for HDV in Final Cut. I am not sure if later version can print HDV to tape either but I am pretty sure it doesn’t work in that vers.
    You could try searching the forum as it has come up many times before.
  • Phil Giriodi
    October 25, 2009 at 9:41 pm
    Thanks Michael. I will upgrade next week once present project is completed.
    However, the print-to-tape window and footage is displayed on my computer monitor, it just won’t bump over to tape. (???)
  • Michael Gissing
    October 25, 2009 at 11:05 pm
    Do a search of this forum. It may not be possible to print to tape in HDV. I just don’t know so you will have to do a bit of research.
  • Zane Barker
    October 26, 2009 at 3:07 am
    I believe that it is edit to tape that is not possible with HDV.
    When printing to tape HDV must conform, and that will take a LONG time.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Jerry Alto
    October 29, 2009 at 9:47 pm
    Phil- You should be able to print to tape. Go to Audio/Video Settings A/V Devices. Make sure the box ‘Different Output for Edit/Print to Tape’ is NOT checked. When it starts the conforming process (HDV) you’ll know you are good to go.
    HTH,
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
