Activity Forums Avid Media Composer FPS problems after render
  • FPS problems after render
    Posted by George Seven on May 31, 2011 at 1:43 pm
    After render a 15 mins sequence (short film) I have FPS problems in my MC5. Everything run nice and clean before render, I’ve got problems only after rendering the entire sequence.
    Do anyone know what is the problem?
    I have a Mac Pro dual quad core 2,4 ghz, 6GB of RAM,ATI Radeon HD 5770video card, 3 hard disk serial ATA 7200rpm.
    thanks!
    John Pale replied 15 years, 3 months ago 3 Members · 6 Replies
  • Job Ter burg
    May 31, 2011 at 3:13 pm
    What resolution did you render to? Your drives may or may not be up to it.
  • George Seven
    May 31, 2011 at 11:10 pm
    It’s a HD project shot in super 16mm. Resolution 1920×1080 25fps, dnxHD 185.
  • John Pale
    June 1, 2011 at 1:49 pm
    Go to your Media Creation settings. If your renders are set to something higher Res than DNX 185, that could be the problem.
  • George Seven
    June 7, 2011 at 11:35 am
    Yes, some render are set at a higher resolution. To be precise, my titles are set to 1:1 and come still images I imported for keying effects are set the same, 1:1.
    How can I change the resolution of an imported image (or video)? How can I recreate the titles at the right resolution?
    thanks for your help.
  • John Pale
    June 8, 2011 at 12:24 am
    For Graphics:
    Batch Import (select all files, instead of offline only). Select to use Current Settings instead of original setting. Change current settings to DNX 145.
    For Titles:
    Select Recreate Title Media. Select DNX 145 as your resolution.
    Check the help menu for more info, if necessary.
  • John Pale
    June 8, 2011 at 12:26 am
    Actually, I meant 185 not 145. DNX 145 is for NTSC.
