Activity Forums Apple Final Cut Pro Legacy fps not matching from camera to FCP
  • fps not matching from camera to FCP
    Posted by David Bark on August 30, 2010 at 2:03 am
    Hi guys. HVX was set and recorded video at 480i/24p. (Recorded to P2 card.) When I brought the footage into FCP, ii’s 29.97. I know I’ve gotten 23.98 into FCP at 720. Is this some kind of pull down mystery for 480 that I’m unaware of?
    David Bark
    Lightshine Productions
    Shane Ross replied 16 years ago 2 Members · 1 Reply
  • Shane Ross
    August 30, 2010 at 2:29 am
    Well, 480i is a 29.97 format. 24p will get you the film look, but remain at 29.97. 720p24 does 24p in a 60 frame format…UNLESS you choose 720p 24PN. Then it shoots 23.98…24p NATIVE. 1080i24p is also a 29.97 format.
    You either need to shoot 24pA (haven’t shot DV with that camera to P2)…if it offers that option. Then you’d be able to REMOVE PULLDOWN when you import.
    Shane
