  • Posted by Rob Simpson on May 11, 2009 at 6:15 am
    Hi everyone,
    I’m new to Final Cut (and editing in general). I am currently editing a documentary and it appears as though our footage has been shot in both 24 & 30 fps. Is this going to be a major problem?
    Many thanks,
    RS
    Craig Thomas quinlan replied 17 years, 3 months ago 3 Members · 2 Replies
  • John Fishback
    May 11, 2009 at 2:11 pm
    If you know what your delivey format is then make that your sequence frame rate convert the other footage to that using Compressor. Search this forum and the FCP forum and you’ll find many posts about how to do this.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Craig Thomas quinlan
    May 13, 2009 at 5:26 pm
    Without knowing the source of this footage it’s hard to say, but while FCP will technically support mixing your frame rates, stick to the one that you’ll finish on. Don’t just drop your 29.97 footage onto a 23.98 timeline mixed with other 23.98 material and expect it to look right. If you didn’t shoot your 29.97 with pulldown, you might want to edit at 29.97….if you shot it with pulldown, you have several options for pulldown removal (cinema tools, compressor reverse telecine). Depends on what you need to deliver at.
