Activity › Forums › Apple Final Cut Pro Legacy › Fps in FCP ?
Fps in FCP ?
Posted by James Mortner on October 7, 2010 at 12:50 pmHello all,
I’ve been trying to edit and work with 16fps footage in its native frame without success. I had to go back to FCP6 and make a new sequence with the right frame rate and drag into FCP7. Seems rather odd that a feature of arbitrary frame rates got removed ?
Or am I doing FCP7 a wrong ?
Thanks all !
Rafael Amador replied 15 years, 10 months ago 3 Members · 6 Replies -
Tom Wolsky
October 7, 2010 at 1:26 pmFCP never had arbitrary frame rates. It has always been frame rate specific to standard video frames 23.976 and higher.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Tom Wolsky
October 7, 2010 at 1:34 pmNot in any FCP sequence you didn’t. You might think it was 16fps, but it wasn’t.
All the best,
Tom
Rafael Amador
October 7, 2010 at 1:42 pmQT allows to making movies with lower fps’s for animations, but as Tom says, FC only works with standard video time-bases.
rafael -
James Mortner
October 7, 2010 at 3:20 pmOk sorry, I fibbed a bit before. You have to export an XML documnet and manually change the fps to
16. This seemed to work as a nasty bodge-job -
Rafael Amador
October 7, 2010 at 4:17 pmIt may be possible to do it in Compressor (8, 10, 12 and 15fps), but I’ve never tried.
rafael
