  • Darby Edelen
    November 29, 2007 at 5:51 am
    fps does not determine the number of frames in your footage, it only determines the number of frames displayed per second. If you render at 24fps and have a 2 second composition, that’s 48 frames (24 frames/second x 2 seconds). If your composition is 3 seconds long then that’s 72 frames.
    Please supply more information about the problem you’re having.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
