Activity Forums Panasonic Cameras FPC not importing CONTENTS file
  • FPC not importing CONTENTS file
    Posted by Pada01 on February 21, 2006 at 7:33 am
    I know there must be simple solution.
    After copying the Contents folder from the P2 card to the hard drive, FPC 4.5 HD will not import the Contents folder.
    I am using the
    Shane Ross replied 20 years, 7 months ago 3 Members · 3 Replies
  • Jan Crittenden livingston
    February 21, 2006 at 10:47 am
    The answer is FCP 5.04.
    Best,
    jan
  • Pada01
    February 21, 2006 at 4:44 pm
    It is simple. Thanks and hope your leg is better.
  • Shane Ross
    February 22, 2006 at 5:31 pm
    Did you figure it out?
    After you get FCP 5.0.4, you need to to FILE>IMPORT>Panasonic P2. You don’t do it the way you were describing.
    Shane
    Alokut Productions
    http://www.lfhd.net
