Activity Forums VEGAS Pro FourPoints Script Not Working
  • FourPoints Script Not Working
    Posted by Bill Cortez on February 19, 2009 at 5:11 am
    I’m using Vegas Pro 8c and I can’t get Edward Troxel’s FourPoints script to run (I saved it as a .cs file, I also tried .js). I get an error message that says: “Exception thrown by message called.”
    In the details it says in part: “System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.ApplicationException: Failed to add envelope point (point may already exist at that location).
    at Sony.Vegas.EnvelopePoint.AddSelf(IEnvelopeOwner owner, EnvelopeType type)”
    I can run the scripts that came with the installation. Thanks, Bill.
    Bill Cortez replied 17 years, 7 months ago 3 Members · 3 Replies
  • John Rofrano
    February 19, 2009 at 12:41 pm
    Do you have an envelope point at the location already? I’m not familiar with the script but I assume you must first make a timeline selection and then it creates a 4-point envelope within the selection. Perhaps you didn’t make a timeline selection first? If you can point me to the script, I can take a look for you.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Edward Troxel
    February 19, 2009 at 2:34 pm
    Here’s the current version of that script for Vegas Pro 8.
    * This script will set four points around the selection area on all selected tracks.
    * Written By: Edward Troxel
    * Copyright 2004-2009 - JETDV Scripts
    * Modified: 07-18-2006
    using System;
    //using System.IO;
    //using System.Windows.Forms;
    using Sony.Vegas;
    public class EntryPoint
    Vegas myVegas;
    public void FromVegas(Vegas vegas)
    myVegas = vegas;
    //Change this line to change the distance between the points
    Timecode FPDist = new Timecode("00:00:01:00");
    foreach(Track track in myVegas.Project.Tracks)
    //Now check for Volume Envelope
    if (track.IsAudio() && track.Selected)
    // Find the volume envelope on this track - add if needed
    Envelope VolEnv = FindEnvelope(track, EnvelopeType.Volume);
    if (null == VolEnv)
    VolEnv = new Envelope(EnvelopeType.Volume);
    track.Envelopes.Add(VolEnv);
    double ClipVol = VolEnv.ValueAt(myVegas.SelectionStart);
    //Now set the points
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart, ClipVol);
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart - FPDist, ClipVol);
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart + myVegas.Transport.LoopRegionLength + FPDist, ClipVol);
    SetPoint(VolEnv, myVegas.Transport.LoopRegionStart + myVegas.Transport.LoopRegionLength, ClipVol);
    private Envelope FindEnvelope(Track track, EnvelopeType etype)
    foreach(Envelope env in track.Envelopes)
    if (env.Type == etype)
    return env;
    return null;
    private void SetPoint(Envelope menv, Timecode PLoc, double PVal)
    EnvelopePoint a = menv.Points.GetPointAtX(PLoc);
    if (a == null)
    a = new EnvelopePoint(PLoc, PVal);
    menv.Points.Add(a);
    else
    a.Y = PVal;
    Just save it as “FourPoints.cs” and it should do the job for you. You do need to have a selection area (it will still work even if you don’t but won’t give you what you want) and a selected audio track.
    Edward Troxel
    JETDV Scripts
  • Bill Cortez
    February 19, 2009 at 4:36 pm
    Thanks Ed, I had the audio track and the event selected, but I didn’t make a selection area–that did the trick. Cool, your script will save me a lot of time editing, appreciate it a lot. Bill.
