Activity › Forums › VEGAS Pro › Four point node machine gun shortcut
  • Four point node machine gun shortcut
    Posted by John Perez on January 18, 2015 at 11:54 am
    I want to lay down four nodes to control an envelope. I know there’s a way to do it because I’ve accidentally done it before. Instead I have to manually add each node along the envelope. Does anybody know how to do this?
    As always thanks so much to you guys…Johnny In Orlando
    John Rofrano replied 11 years, 8 months ago 2 Members · 3 Replies
  • John Rofrano
    January 18, 2015 at 3:33 pm
    [John Perez] “I want to lay down four nodes to control an envelope. I know there’s a way to do it because I’ve accidentally done it before. Instead I have to manually add each node along the envelope. Does anybody know how to do this?”
    Create a Timeline Selection of the area that you want to control and then left-click your mouse to pull down on the envelope line and 4 nodes will magically appear at the edges of the selection.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Perez
    January 18, 2015 at 10:16 pm
    John Rofrano, you are simply the best.
  • John Rofrano
    January 18, 2015 at 10:39 pm
    I assume it worked. 😉 great!
    ~jr
