Activity Forums Apple Final Cut Pro Legacy Four Channel Audio Mix to Tape
  • Four Channel Audio Mix to Tape
    Posted by Craig Ernst on July 28, 2005 at 10:47 pm
    In editing my shows I typically have VO on audio Track 1, nat sound and FX on audio Track 2, and stereo music on audio tracks 3,4,5&6.
    I want to output this to HDCAM tape in a FOUR channel audio mix. I would like Audio track 1 9from timeline) to go to audio track 1 on tape and Audio track 2 (from timeline) to go to audio track 2 on tape and I would like audio tracks 3,4,5,6 (from timeline) to go to audio tracks 3&4 on tape.
    In the world of avid there was a simple way to map audio wherever you wanted to and mix all the music tracks could just go to a stereo mix on tape.
    How do I do this in FCP.
    Craig
    Jerry Hofmann replied 21 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 29, 2005 at 2:07 am
    From the Manual:
    To create a new audio output preset:
    1 Choose Final Cut Pro > User Preferences, then click the Audio Outputs tab.
    2 Choose a preset from the audio output Presets list, then click Edit or Duplicate.
    3 In the Audio Outputs Preset Editor, enter a name and description for the preset.
    4 Choose the number of audio channels you want to access on your audio interface.
    5 For each pair of audio channels, choose Stereo to allow for panning clips between the pair
    of channels, or choose Dual Mono so that each channel can be used as a discrete output.
    6 Choose a downmix level for each pair of outputs.
    7 Click OK, then click OK again.
    To change the default audio output settings assigned to all new sequences:
    2 Select an Audio Output preset from the Presets list by clicking in the column next to
    the preset
