Activity › Forums › Blackmagic Design › Four Channel Audio Mix to Tape
  • Four Channel Audio Mix to Tape
    Posted by Craig Ernst on July 28, 2005 at 10:47 pm
    In editing my shows I typically have VO on audio Track 1, nat sound and FX on audio Track 2, and stereo music on audio tracks 3,4,5&6.
    I want to output this to HDCAM tape in a FOUR channel audio mix. I would like Audio track 1 9from timeline) to go to audio track 1 on tape and Audio track 2 (from timeline) to go to audio track 2 on tape and I would like audio tracks 3,4,5,6 (from timeline) to go to audio tracks 3&4 on tape.
    In the world of avid there was a simple way to map audio wherever you wanted to and mix all the music tracks could just go to a stereo mix on tape.
    How do I do this in FCP.
    Craig
    Matthew Small replied 21 years, 2 months ago 2 Members · 1 Reply
  • Matthew Small
    July 29, 2005 at 12:33 am
    You need to have your project set up for four channel which is done by creating a four channel preset under User Preferences and Audio Outputs. Then, change your Sequence Settings under Audio Outputs to the 4 channel preset you just created. If you right-click (or control-click) in the space to the left of the track label, you can set which output channel each track goes to.
    Matt Small
    Pair of Hands
    Sherman Oaks, CA
    “If it was easy, everyone would do it.”
