Activity › Forums › Adobe Premiere Pro › Four Boxes with videos playing inside of them.
  • Four Boxes with videos playing inside of them.
    Posted by Will Flowers on May 12, 2008 at 9:03 pm
    I am creating a DVD and I want to have several clips playing at one time in different spaces of the screen.
    For example, at one point the voiceover mentions severals electrics outlets around the trailer (this is for a trailer company). I want four boxes to appear on the screen in an order the first (top left), then the second (top right), followed by the third (bottom left), and finishing with the fourth (bottom right).
    Is this possible in PP? Or is it something I need to do in After Effects?
    Will Flowers replied 18 years, 4 months ago 3 Members · 3 Replies
  • Perry Cheng
    May 12, 2008 at 10:05 pm
    PiP (Picture in Picture). Any NLE can do. Premiere has some presets make it easier. Look in the effect drop down, and find pip. You may have to make some value changes on them for fit your needs?
    Perry
  • Steven L. gotz
    May 13, 2008 at 1:29 am
    Basically you just scale the clips to 50% and change the position parameter to put each in the appropriate corner. And yes there are presets if you wish to use them.
    Steven
    https://www.stevengotz.com
  • Will Flowers
    May 13, 2008 at 2:16 pm
    Thank you to both. Very helpful.
