Activity Forums Adobe After Effects Foundry Keylight 1.1 error in AE CS3
  • Foundry Keylight 1.1 error in AE CS3
    Posted by Anjum Gill on June 26, 2008 at 12:21 pm
    Hi
    I am using After Effects CS3, I am usging foundry keylight 1.1 for CS3 but I cannot render my composition which is 2 minutes long and its crashing giving this msg “crash occured while invoking effects plugin keylight (1.1)” Any one know what this is ?
    Any help would be much appreciated
    Anjum Gill replied 18 years, 2 months ago 2 Members · 4 Replies
  • Joey Foreman
    June 26, 2008 at 6:09 pm
    Why are you using 1.1? AE CS3 ships with Keylight 1.2.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Anjum Gill
    June 27, 2008 at 6:01 pm
    Hi Dave
    Thanks for responding to my post, I hope this will answer all your Questions about camera and footage spec.
    Camera is JVC MG505 3CCD
    Pixel aspect ratio:
    Standard NTSC video 4:3 interlaced
    Type: MPEG Movie
    File Size: 122.3 MB
    Image Size: 720 x 480
    Pixel Depth: 720
    Frame Rate: 29.97
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00;01;48;02
    Average Data Rate: 1.1 MB / second
    Pixel Aspect Ratio: 0.9
    In addition to this here are my System spec
    OS: XP Pro SP3 32bit
    processor: AMD Phenom 9500 quad core
    Ram: 4GB
    AGP: Nvidia 8600GT
    harddisk: 750GB Sata II
    I beleive it has something to do with memory & chahe although the maximum ram chache size was set to 60% which is a standard.
    I did try something yeasterday, by decreasing the maximum ram chache size from 60% to 40% I was able to render it without error but is there any other way around ? many thanks
  • Anjum Gill
    June 27, 2008 at 6:04 pm
    Hi Joey
    Sorry ma bad yes you are right its not Keylight 1.1 it is indeed 1.2 I thought I should make correction to this 🙂
  • Anjum Gill
    June 27, 2008 at 6:31 pm
    Hi Dave
    I probably am not as good as you guys are in posting and responding to forums because I did miss out a very important bit that is the file created by this camera is actually MOD which in other words is MPEG 2 but is not readable in after effects at all.
    So in order to make it work with AE I got a dll files from a friend that makes Adobe Premiere CS3 read this file and then save it in any format, I choose to save it as AVI no compression applied will this make any difference ?
