Activity › Forums › Apple Final Cut Pro Legacy › Found the answer to timecode on quicktime player from FCP
Posted by Dan Riley on May 2, 2007 at 11:39 pmActually Matt, from the AJA forum pointed it out to me.
Here’s what you do: either a clip in the viewer or a sequence,
you export a quicktime ref movie first, then drop that into compressor
to make the h.264. Don’t do a quicktime conversion in FCP and do the
h.264 that way. I tried it from an original DV captured clip also, just
dropping it in compressor to make the h.264 and it works too.
Very cool. Thanks Matt for helping me.Dan
John Pale replied 19 years, 4 months ago 3 Members · 11 Replies -
David Roth weiss
May 3, 2007 at 12:38 amOdd, but it does not seem to work with 8-bit uncompressed. The captured file does show timecode in the QT player window, but when I export an H264 of that from Compressor it has no timecode.
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
David Roth weiss
May 3, 2007 at 1:25 amAnalog video doesn’t work, looks like all digital formats do…
David Roth weiss
May 3, 2007 at 1:42 amSee my first post above. I meant captures from analog format such as BetaSP captured as 8-bit uncompressed. It clearly has timecode that shows in QT player, but it doesn’t tranfer oevr to an H264 conversion in Compressor.
Dan Riley
May 3, 2007 at 1:50 amInteresting.
I’ll try it tomorrow at the office.
But my stuff is 10 bit, and was from DigiBeta but from BetaSP masters.
What card are you using and what codec to do the 8 bit captures?
I use Aurora Pipe Studio and Aurora 10 bit uncompressed codec.
We’re still an SD house, until this summer.Dan
David Roth weiss
May 3, 2007 at 1:58 amUsing a Kona LH to capture Beta to Kona 8-bit uncompressed, whgich is the very same thing as Apple 8-bit uncompressed.
I’m guessing any digital format captured via firewire or SDI will allow the timecode to transfer over, but nothing captured via analog component.
It just a guess, but it seems to be so…
DRW
Dan Riley
May 3, 2007 at 2:39 amWell that is a different problem. You are saying your 8 bit clips from BetaSp
don’t have the original timecode from the tape on the captured 8bit
quicktime clips? Don’t you have rs422 connected from the BetaSP to your KONA card?Dan
David Roth weiss
May 3, 2007 at 3:40 amNope, you misread my post. I said the captured 8-bit does have timecode, it shows up in QT player, but that timecode does not show up after making an h264 conversion in Compressor.
John Pale
May 3, 2007 at 12:37 pmImport the H264 clip into FCP…load it into the viewer, then use the Modify Timecode command to add the correct timecode to it.
Easy.
Dan Riley
May 3, 2007 at 3:02 pmThis is not the workflow I’m trying for.
The idea is, instead of making DVDs with burned in timecode from
DigiBeta or BetaSP playback, we can take a firewire drive of backup files
and have someone drop those files into compressor to make h.264
files then upload to our site for online viewing. Even a computer without FCP.
With the discovery yesterday of how to do it, this important addition
to the quicktime player eliminates a real-time expensive step in the
process. Having to go through your process on hundreds of files,
in my opinion would increase the chance for errors as well as tying up
a workstation. For the one-off sequence now and then, yes I can see
doing your process so thanks for showing us to do that. I’m sure it will
come in handy.Dan
