Activity › Forums › Blackmagic Design › found a bug ???
  • found a bug ???
    Posted by Massimo Croce on October 18, 2005 at 10:01 am
    hi Guys
    I m an ex avid editor migrate to fcp
    i like to have audio separate from video
    but when i check to capture it separate from video
    (i ve tested many times tring anything trash preference unistalling plug in etc) i discovered
    that when i lunch a batch digitize from fcp
    the process stop before it is terminate
    i tried to batch digitize a clip 1 min long
    and it ever stop (ever) at 48″14 frame
    with separate audio checked
    nothing wrong with separate unchecked
    can someone replicate the problem
    and find a solution
    my sistem is
    dual g5 2,3 ram 1,5 fcp 5,02 BMD drivers 5,1
    work on pal 8 bit
    thanks
    Luke Maslen replied 20 years, 11 months ago 2 Members · 1 Reply
  • Luke Maslen
    October 19, 2005 at 1:45 am
    Hi Massimo,
    This is a bug in Final Cut Pro HD 5.0.2 and we have previously logged it in Apple’s Radar bug tracking system with Radar bug number 4196111. Apple are aware of the problem and are investigating a solution so hopefully one will be found soon. The only workaround, of which I am aware, it to use SDI video with embedded audio.
    Keeping audio seperate from video is an old workflow which used to be the standard. Once Apple fix this bug, you should be able to continue doing that if you like as that’s what Avid systems still do and you would be familiar with that workflow.
    However I would encourage you to consider using SDI video with embedded audio. The movies that you capture will contain both the video and audio and keeping them together eliminates potential technicalities. It’s also nice to be able to capture everything in one cable and output via one cable. It makes it so much easier to connect to decks and cameras and other gear if you can just use embedded audio at all stages.
    Do you have a particular workflow where you need to capture to seperate audio and video files or is this just a preference from your familiarity with Avid systems?
    Regards,
    Luke Maslen
    Blackmagic Design
