Activity › Forums › Adobe After Effects › forming dash lines
forming dash lines
Posted by Ong Joseph on June 29, 2008 at 3:51 pmHi,
Can anyone suggest a way to form a “dash line” that can move around in 3d space with particular? I tried using a rectangular solid as a custom particle but it doesn’t look right.
Oscar Edvardsson replied 18 years, 2 months ago 2 Members · 5 Replies -
Oscar Edvardsson
June 29, 2008 at 5:00 pmI’m not sure exactly what you want, but I guess you can use spheres and crank up the particles per second. Set the velocity to 0 and keyframe the particles per second. There is an expression to circle keyframes if I don’t remember incorrectly.
Ong Joseph
July 3, 2008 at 2:27 amSorry. Guess I was unclear. I’ve seen posts on how to create dotted paths on this forum but instead of dotted paths, I’m looking to create dash lines that form the path, instead of circles, rectangles. However, I need to move it along in a 3d space.
Oscar Edvardsson
July 3, 2008 at 1:56 pmAh, hm. Try this
1) Create a light with the name Emitter
2) Create a new solid and apply the Particular effect
3) Set the Emitter Type to Light
4) Set Particle Per Second to something high (like 100, 200 depending on how fast it’s moving) and keyframe it at 0:00. Move forward a bit in time (like 15 frames), set a new keyframe with the value of 0. Move forward another 15 frames and set a new keyframe with the value of 100. Toggle all keyframes to Hold (at least the two first).
5) Add the expressionloop_out("cycle",0)to the Particle Per Second-attribute.
6) Go to Particle->Life and set it to something that you think seem fit (like the duration of the comp).
7) Go to the light and add the expressionwiggle(0.5,100)to it’s position.If I haven’t forgot anything and you have done all correctly, you should have a dashed line moving around randomly, in 3d-space. The distance of the keyframes for Particles Per Second determines the length of the dashes and empty space. You might need to increase the higher value if you increase the speed in which the light is moving and so forth.
And how you animate your light is up to you.I took time to try it and upload both the render and the project.
Render
Project file -
Ong Joseph
July 4, 2008 at 4:52 pmThank You Oscar. Truly appreciate time taken to help. I will tweak the setting to achieve the desired effect.
Joseph
