Activity Forums Adobe After Effects FORM>GLOW>PROBLEM> Expert Needed
  • FORM>GLOW>PROBLEM> Expert Needed
    Posted by Lincoln Waldron on February 11, 2010 at 3:29 pm
    OH so I have a comp 1
    Comp 1
    -PSD file trace (Logo) with Trapcode Stroke duplicated 3 times and each one pre comped with varying glow effects to create a Neon sign of the Logo.
    I want to make this explode in Trapcode form then reform.
    My problem is when I layer map it to this logo pre comp with the 3 pre comps inside it.
    the glow just floods the particles and doesnt give me an accurate image of the Logo (Neon sign).
    Does this make sense?
    *My pixels are all the right size
    -I have the correct amount of pixels
    -Its all in the feathered glow flooding over – which I need to make it a neon Sign.
    Please help me if you could?
    Lincoln Waldron replied 16 years, 6 months ago 3 Members · 3 Replies
  • Michael Szalapski
    February 11, 2010 at 8:12 pm
    I’m not quite seeing what you’re talking about in my head from your description. A screen capture would be helpful. (Print screen button on the PC, paste into Photoshop. On the mac use the screen grab utility, I forget the name.)
    Is the glow effect inside the precomp or is it applied on the layer map layer? Or is it applied on the Form layer?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Philippe Lessard
    February 11, 2010 at 10:24 pm
    Try to disable the glow in your precomp, and have you set your fonctionnality(in form layer map) to rgba to rgba, and in the proper dimension?
    I bet is the glow inside the precomp!
  • Lincoln Waldron
    February 15, 2010 at 10:31 pm
    I worked the problem out.
    All I needed to do- was add a black Solid as my background within my pre comp.
    L
