Activity Forums Apple Final Cut Pro Legacy Formatting Questions
  • Formatting Questions
    Posted by Matthew Cook on December 15, 2008 at 4:26 pm
    I’m trying to make the best of a less than desirable set of circumstances. I’ve learned a lot by reading back through threads on the Cow and am about to start my project over.
    I have concert footage from two sources in two different formats:
    From Canon HV20–
    29.97 FPS
    1440 X 1080
    HDV 1080i60
    Data Rate: 3.2 Mb/sec
    Pixel Aspect: HD 1440 X 1080
    From unknown DV Camera–
    29.97 FPS
    720 X 480
    DV/DVCPRO/NTSC
    Data Rate: 6.9 MB/sec
    Pixel Aspect: NTSC-CCIR 601
    By following The instructions in ‘Uprezzing DV to DVC Pro HD’ by Shane Ross I’ve converted the DV footage to:
    29.97 fps
    1920 X 1080
    Apple Pro Res 422 (HQ)
    Data Rate: 25.5 Mb/sec
    Pixel Aspect: Square
    So my questions: Have I gotten the best results I can out of the DV footage?
    Should I also run the Canon footage through Compressor before combining the two sources in the timeline? Make them more similar to each other?
    I’m working in FCP Studio 2
    Nick Haffie-emslie replied 17 years, 9 months ago 3 Members · 3 Replies
  • Chris Borjis
    December 15, 2008 at 5:34 pm
    [Matthew Cook] “So my questions: Have I gotten the best results I can out of the DV footage?
    Should I also run the Canon footage through Compressor before combining the two sources in the timeline? Make them more similar to each other?”
    I think you have gotten the best you can out of the DV footage.
    I would run the canon footage through compressor, or recapture as prores 1080 so it matches.
    one thing though…..was the deliverable SD or HD?
    If it was SD I would have posted the entire thing as SD as that would look more
    uniform than SD being upconverted.
  • Matthew Cook
    December 15, 2008 at 5:46 pm
    Thank you!
    I’m trying to deliver HD for broadcast purposes and SD for DVD as many of my fans don’t have HD players. I’ve found ways to export my sequences as both HD and SD. Is this just pointless? Would I get better results in both cases if I just work in SD?
    One problem I’ve been encountering is that if I zoom in too far on the DV footage it looks like crap.
  • Nick Haffie-emslie
    December 15, 2008 at 6:10 pm
    You may want to check with the broadcaster about specifications before you get too deep into this project. Many will not accept uprezzed SD footage and are pretty specific about origination format requirements for HD.
