Activity › Forums › VEGAS Pro › Formatting from FAT32 to NTFS help
  • Formatting from FAT32 to NTFS help
    Posted by Carson Young on March 3, 2007 at 3:32 am
    I’ve just realized my external hard drive needs to be reformatted to NTFS. Everytime i capture video it breaks up the footage into about 18 min clips. Im assuming that I need to reformat it from FAT32 to NTFS to solve this problem.
    1) Is this correct?
    2) If I reformat the hard drive without moving existing files that are currently there, will they be erased?
    Thanx,
    Carson
    Anoni Moose replied 19 years, 7 months ago 5 Members · 6 Replies
  • Terje A. bergesen
    March 3, 2007 at 6:13 am
    convert X: /fs:ntfs
    Replace X with the drive letter of the drive that you want to convert. This converts to NTFS with no data loss.
  • Neil Moxham
    March 3, 2007 at 6:55 am
    Is this really true !!
    That you can convert a filing format system without a complete wipe and reformat !!!??????
    If so ..I will be ecstatic.
    I cant tell you howmany times I have gone thru the rigorious process of formating to NTFS after buying a new drive. let alone the backup software that is already on it.
    Are there any drawbacks to this method
    Where do you run this command from ?
    Zipedit
  • Edward Troxel
    March 3, 2007 at 2:00 pm
    Start – Run – and then type in that command.
    Edward Troxel
    JETDV Scripts
  • Carson Young
    March 3, 2007 at 6:13 pm
    Thanx for the help guys, but i may have done somthing wrong im guessing. I went to start>run>(typed in) convert H: /fs:ntfs (with that exact spacing), it went through the drive really fast like 5 seconds or so, i watched it go from 1-100%, but after it was done and i checked the drives properties and it still said it was fat32. There was no data loss.
  • Terje A. bergesen
    March 4, 2007 at 9:02 pm
    The problem with doing start->run is that you won’t see if there are any error messages etc. Do the following:
    start->run “cmd”
    in the “dos” window that opens, run
    convert H: /fs:ntfs
    chkdsk H:
    The output from chkdsk h: should read
    C:\>chkdsk H:
    The type of the file system is NTFS.
    WARNING! F parameter not specified.
  • Anoni Moose
    March 5, 2007 at 7:42 am
    In any case, I’d suggest making sure a backup of that disk is done first, even if it’s not supposed to be destructive.
