Activity Forums VEGAS Pro Formatting for Facebook problems
  • Formatting for Facebook problems
    Posted by Rob Lindsay on February 14, 2019 at 8:59 pm
    Trying to format footage shot at 1920×1080 to 1080×1080. I’m close but I still have bars on top and bottom or it’s stretched up and down. I’ve attached a screen shot. Your help is greatly appreciated!
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
    George Dean replied 7 years, 6 months ago 2 Members · 8 Replies
  • 8 Replies
  • George Dean
    February 14, 2019 at 10:24 pm
    Hi Rob,
    Open up Pan & Crop and right click on the video displayed and select ‘Restore’. That should set everything back to default.
    Then check to assure the icon ‘Lock Aspect Ratio’ is un-checked (the icon will look like lock with XY in the background.
    Then under ‘Position’ change the ‘width’ to ‘1080’ to match the height, making it a square. You can then move the square border viewing area around to show whatever past the 1920 width you want included. You can also animate this if needed.
    When you render, in the render template change the ‘Frame size:’ to ‘Custom Frame Size’, then manual change the width of 1920 to match your square ‘1080’. Render out and enjoy.
    Best Regards……George
  • Rob Lindsay
    February 14, 2019 at 10:46 pm
    Thank you, George. I think that’s what I had done previous to my first email, because the outcome is the same, as you can see from the new screen shot. The timeline image is squeezed. I did begin with a custom template of 1080×1080. Do I need to go back and start with 1920×1080?
    Thank you,
    Rob
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • George Dean
    February 14, 2019 at 11:58 pm
    That’s what I would do, make the Project frame size match your source media and make the changes as I outlined above and it should come out dandy.
  • Rob Lindsay
    February 15, 2019 at 3:59 am
    Thanks, George — I’m gonna have at it!
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • Rob Lindsay
    February 15, 2019 at 10:42 pm
    Hi George
    The process works, but I have to do it to each clip this way. Can I toggle a track control for this or do i have to wait to render then crop that?
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • George Dean
    February 15, 2019 at 11:41 pm
    Hi Rob,
    There are a couple ways to move this along quicker, you will like No. 2 I think.
    1. I would suggest setting this up with the event/clip, then save your changes as a preset. Then I realized I had not looked at the presets!!!! Sure enough there is a 1:1 preset in Pan & Crop already. I think this is included by default.
    2. Use the Pan & Crop preset to setup the 1:1 Square dimensions. Make sure that event/clip is selected, right click and select ‘Copy’. Then select the next event/clip, move to the end of the project, hold down ‘Shift’ then click on the last event/clip, this will select all the events/clips in your project, Right click on any of the selected events/clips and select ‘Paste Event Attributes’. That should then copy the Pan & Crop from the first event you copied into all the rest of the events you mass selected.
  • Rob Lindsay
    February 17, 2019 at 4:41 pm
    George, I used method #2 — and Bob’s your uncle!
    Thank you again for your help and patience.
    Rob
    Vegas 13.545
    Dell Windows 10
    Intel 6700 quad CPU
    16 Gigs RAM
    3 Gig GPU
  • George Dean
    February 17, 2019 at 8:40 pm
    Good to hear it is working out for you Bob.
