Activity › Forums › Apple Final Cut Pro Legacy › Formatting everything – Please advise…
  • Formatting everything – Please advise…
    Posted by Josh Evans on May 16, 2008 at 11:15 am
    OK I’ve decided to do the massive thing of formatting Zeroing all data on my hard disk and externals.
    Could anyone please tell me the optimum settings to choose for formatting?
    If im right, I should do everything as Mac os x Extended. But what about HFS+ ? I cant find this setting anywhere?
    Jeremy Garchow replied 18 years, 4 months ago 5 Members · 5 Replies
  • Steve Eisen
    May 16, 2008 at 11:29 am
    Look for Mac OS Extended turn Journaling off.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Josh Evans
    May 16, 2008 at 11:30 am
    Ok thanks, thats what i thought.
    cheers.
  • Rafael Amador
    May 16, 2008 at 11:38 am
    Josh,
    Zeroing is just to make sure that any trace of any document is overwrited.
    I don’t see this very necessary, unless you have state secrets and you are afraid that somebody will still your HD and recover the information:-)
    And a “zeroing’ in deep, takes ages.
    If you are going to format your external HDs, check Mac OX Extended (NOT JOURNALED).
    If you will re-install your system, the installer will format the HD as Mac OX Extended Journaled. About the HFS+ you don’t have to worry. All the Mac OX Extended options formats as HFS+. Only the FAT32 option don’t.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Tom Wolsky
    May 16, 2008 at 1:16 pm
    You should zero out drives that have ben previously formatted as DOS and used. Even if there are no state secrets on it, you should do this. Erasing a drive simply dumps the directory. I was told that because DOS formatting using a different directory structure, parts of it will get left behind on the drive and can cause problems. Segments will still have DOS directory information on it that will not be written over.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Jeremy Garchow
    May 16, 2008 at 7:10 pm
    [Steve Eisen] “turn Journaling off.”
    Here we go with this again.
    This is not necessarily true. Journaling does not need to be off.
    What kind of externals do you have, Josh?
