Activity › Forums › Adobe Premiere Pro › Formatting an old DVD using CS5.5.2
Posted by Bob Dix on October 15, 2017 at 11:56 amI am having trouble formatting an old DVD 4 x 3 to run normally in Premier Pro CS 5.5.2 and then uploaded to You Tube, but, I cannot get it right, the video looks squashed ? Attached is the You Tube link . I just cannot get it right on the timeline, any ideas ?
Bob Dix Photographer
Freelance Imaging & Video
AUSTRALIABob Dix replied 8 years, 11 months ago 4 Members · 8 Replies -
Tero Ahlfors
October 15, 2017 at 11:59 amWhat are your export and sequence settings? You probably have the wrong pixel aspect ratio.
David Roth weiss
October 15, 2017 at 3:29 pmIt should not actually be displayed 4×3, it’s really 4×3 anamorphic or widescreen, thus you should be encoding to the PAL full screen aspect ration of 720×576 (with non/square pixels I think).
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los AngelesDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Ann Bens
October 15, 2017 at 5:21 pmExport to 788×576 with square pixels.
Adobe Certified Expert Premiere Pro CS2/CS6/CC
Adobe Community Professional -
Bob Dix
October 15, 2017 at 10:12 pmAnn,
I do not know how to “Export to 788×576 with square pixels” and I have gone onto Sequence settings ?
AUSTRALIA -
Bob Dix
October 15, 2017 at 10:14 pmTero,
You are right, but, how do you change the settings from standard ?
AUSTRALIA -
Bob Dix
October 15, 2017 at 10:18 pmI certainly have the wrong pixel settings, but, how do you change it, Ann suggests Export to 788×576 with square pixels and I think it will fix the problem, but, how do you change the Sequence settings, there appears no manual changes possible ?
It was videod in standard 4 x 3 , it was a long time ago before widescreen .
AUSTRALIA -
Bob Dix
October 16, 2017 at 12:34 amAnn,
I got desperate >
13. Re: Formatting an 7 year old Pal 720×576 dvd in Premiere Pro CS5.5.2
Bob Dix
Level 2
Bob Dix Oct 16, 2017 10:21 AM (in response to Stan Jones)
Stan,I finally tried using Movie Studio 14.0 Platinum which I hardly rarely use . Put the DVD in the program and it automatically imported as the correct format, then sent it to You Tube and I extracted all the stills I required within 10 minutes, I was truly amazed. There was no distortion in the movie or the stills for printing in Photoshop.
I would still like to know how you would do it in Premiere Pro ?
Correct Answer
Helpful Like Show 0 Likes(0) Reply Actions
Translate
14. Re: Formatting an 7 year old Pal 720×576 dvd in Premiere Pro CS5.5.2
Bob Dix
Level 2
Bob Dix Oct 16, 2017 10:31 AM (in response to Bob Dix)
I then extracted the Movie Studio v14 Platinum mpeg file and imported it into Premiere Pro and it worked perfectly, the right format and no distortion in the final video ? Everything worked including all the effects. Huuuuuuuuuum, why is it so ?
Correct Answer
HelpfulBob Dix Photographer
AUSTRALIA -
Bob Dix
October 16, 2017 at 6:41 amYes Ann,
You were right, Export to 788×576 with square pixels. But, I used Movie Studio HD Platinum v 14, it just did it automatically and then automatically uploaded the file to You Tube, the the video looks spot on.
At my age I did not even have to think about doing much. It was over 15 years ago, and my wife who is from Holland looked pretty good from an old Sony Hi-8 tape recording.
AUSTRALIA
