Activity › Forums › Cinematography › Formatt HD Soft filter for matte box? (& ND grads)
  • Formatt HD Soft filter for matte box? (& ND grads)
    Posted by Bob Woodhead on October 9, 2007 at 10:57 pm
    I’d like to add some filters to my Cavision matte box (4×4 rotating & 4×5.65 non-rotating). Already have a 4×5.65 horizontal Tiffen polarizer. Want to get a graduated ND, probably a .6 ? Would this cover most daylight contrast issues, or should I consider a .3 / .9 as well?
    After seeing firsthand how razor-sharp skin detail is in HD, I’m also thinking it’d be great to have a “soft” filter, perhaps the Formatt HD Soft? Comments / suggestions?
    “Constituo, ergo sum”
    Bob Woodhead / Atlanta
    http://www.CoolNewMedia.net
    Quantel-Avid-FCP-3D-Crayola
    Panasonic HPX500
    Robin Probyn replied 18 years, 11 months ago 3 Members · 5 Replies
  • Todd Terry
    October 10, 2007 at 3:11 am
    As to the ND, I would go ahead and get a .3, .6, and a .9. I personally find I use the .9 more than the other two.
    Plus, if you are a bargain hunter it’s worth noting that several of the filter makers offer an ND set that contains all three of those… usually for substantially less than if you bought all three individually.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
  • Robin Probyn
    October 13, 2007 at 12:19 am
    I think you,ll find the .3 and .6 grad not much use for skies,unless you double them up in the mattbox.I eventually found a 1.2 ND grad and pretty much only use this,it will bring down a very bright sky,and make a darkish sky really moody.
    Also have a Thunder Grad,cant remember the maker,but this is great for skies,ND with some blue.
    Out of habit I once used a 1/4 black promist with a F900 at 24p,and got feed back that it was too soft? as by shooting 24p the image is no where near as sharp as shooting HD in 50i or 60i.
  • Bob Woodhead
    October 13, 2007 at 10:18 am
    Thanks for the feedback. Would you recommend a promist over a soft (the new softs from Tiffen/Formatt designed for HD)? From the sample images (as IF you could make a decision via those!), I prefer the promist, but no idea how they’ll play out in the field.
    While writing this reply, my ignorance overtook me, and I had to go turn on the camera (HPX500) and see just how much I could slide the 4×4 stage vertically (as you would to position a graduated ND). I was *surprised* at how much I could “cut into” the glass, without seeing the esge of the filter tray onscreen! This was with a Fuji 17×7.6 – can I assume that with a wide angle adapter (or lens), there won’t be as much positioning lattitude? How to adjust a ND grad then? (PS – my Cavision mattebox has 1 rotating 4×4 & 1 fixed 4×5.65)
  • Robin Probyn
    October 13, 2007 at 1:22 pm
    Sorry I havnt used the new for HD softs,I use a 1/8th white promist mostly now,to be honest its main purpose is to protect the front element of the lens!
    The filter tray,or mattbox will cut in from the sides before top or bottom.7.6 should be fine,but when you get down to 4.7 you may need a new mattbox.
    You can use the grad in the rotating tray sometimes for (arty) dutch angle shots,etc,no rules really,but its going to look more than a bit strange if you have say a sea horizon in shot.
    Great thing about an ND grad,is you can pretty much see where it is in the eye piece,a colour one is ofcourse not a good idea in a BW eye piece,then you need a good monitor.
    Can also zoom through a grad if you need to grab a long lens shot right then,but best to take it out when you dont need it!
  • Robin Probyn
    October 13, 2007 at 1:26 pm
    Yes the vertical latitude of how far before the tray comes into shot depends on the angle of the lens.The wider the less latitude.
    And mostly you,ll be wanting to use the grad on big wide shots.Landscape stuff.
