Activity › Forums › Apple Final Cut Pro Legacy › Formating FCP Drives? Please Advise
  • Formating FCP Drives? Please Advise
    Posted by Russell on July 26, 2005 at 2:45 am
    I have a few drives that I’m setting up and will be formating under Mac 10.4.2 Disc Utilites … They’re main purpose in life is FCP.
    What flavor should I format them in, Journaled, Extended, etc.
    What’s the difference and or advantage of a particular flavor?
    I’m striping together 8 Hitachi Serial ATA 500GB Drives.
    Also formating two LaCie 1.6TB FW 800 Drives and one LaCie 1TB Drives to use as backup… Not stripping these seperate units.
    Thanks for your time everyone!
    David Bogie replied 21 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    July 26, 2005 at 4:34 am
    They must be formatted Mac OS Extended. Journalling can be on or off, it doesn’t matter. That is pretty much the only format you can use if you intend to capture media to those drives using FCP.
  • Russell
    July 26, 2005 at 6:27 am
    Exactly what is journalling?
  • Shane Ross
    July 26, 2005 at 6:35 am
    To Quote Apple:
    “enhances server availability and fault resilience by protecting file system integrity in the event of an unplanned shutdown or power failure, maximizing server and storage uptime by dramatically expediting repairs to the volumes when the system restarts”
    It is a file that takes note of the file names and types on your hard drive. It doesn’t effect drive performance. Early thoughts were that it did, but it was discovered that it doesn’t.
  • Russell
    July 26, 2005 at 8:32 am
    Very informative… Thanks!
  • Peter Mcauley
    July 26, 2005 at 12:34 pm
    I thought it was generally excepted that journaling was only for OS system drives and not for media drives. Has this thinking changed and why.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.3.8
    FCP 4.5 HD
    QT 6.5.2
    Kona 2 v1.1 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Tom Matthies
    July 26, 2005 at 2:03 pm
    Ditto
    I’ve always read that journaling was NEVER supposed to be used for media drives.
    Tom
  • David Bogie
    July 26, 2005 at 2:31 pm
    Journaling appears to be serious overhead on non-system drives that can possibly interfere with video capture and playback. However, DV isn’t all that intensive and most of the heavy lifting is done by the CPU so a bit of drive overhead shouldn’t matter..
    I’ve formated DV-only Firewire media drives with and without journaling enabled. I see no performance difference but I also see no value in maintaining the journal files.
    There might be a difference for other formats and codecs or for internal SATA drives. Dunno.
    google “osx journaling” for many hours of inconclusively boring reading. Comes down to personal choice, I think.
    bogiesan
