Activity Forums Apple Final Cut Pro Legacy format problems in burned dvd
  • format problems in burned dvd
    Posted by Annu Lilja on September 19, 2008 at 8:34 am
    Hello,
    I burned a dvd using 4:3 settings. Most of the material is digitized Super 16mm film, and that looks fine when burned on a DVD. but I have a little bit of material that is vhs trasferred to dv and imported from a mini dv camera. That material looks squeezed (too narrow) on the burned DVD.
    What’s wrong? Do I need to change my sequence settings before making the quicktime? also, I only used the “use current settings” when making the quicktime for the dvd.
    Thanks for any helpful hints.
    Annu
    Annu Lilja replied 17 years, 11 months ago 2 Members · 2 Replies
  • Rafael Amador
    September 19, 2008 at 10:08 am
    Hi Annu,
    Have you made “Render All” before exporting?
    Have you exported a Self-Contained movie from FC?
    If so, how look the VHS stuff in the exported .mov?
    rafael
    http://www.nagavideo.com
  • Annu Lilja
    September 19, 2008 at 10:59 am
    thanks for your reply. I have done the steps you suggested, and the VHS material still looks wrong. I’m still experimenting here.
