Activity › Forums › Apple OS X › format hard drive for Mac & PC
  • format hard drive for Mac & PC
    Posted by Josh Snider on April 9, 2007 at 7:50 pm
    Hi, I’d like to be able to pass files back and forth between me and the people I work with. They all work on Adobe Premiere on PC’s, and I’m on FCP on a Mac.
    I’ve heard that if I format my external hard drive to FAT-32,then I can upload PC files to the hard drive, then download them onto the Mac, and vice-versa…however, I’ve also been told that the Mac will only be able to read files that are 2GB or less if they come from a hard drive formatted to FAT-32. Is this true? Are there other down-sides to my plan?
    Are there any external firewire hard drives that will not have this quirk involved?
    Josh
    Brad Pemberton replied 19 years, 5 months ago 5 Members · 5 Replies
  • Curtis Thompson
    April 9, 2007 at 8:26 pm
    hello…
    this is a common topic here – also try searching the archives for comments, but this is generally what you would want to do:
    https://www.thexlab.com/faqs/sharefwdrive.html
    any reason to not just network boxes? much easier than hauling a drive between boxes…
    sitruc
  • Josh Snider
    April 10, 2007 at 2:29 pm
    Thanks, I’ll check out the article.
    …You know I had never thought about networking my Mac to a PC. Can that be done pretty easily through firewire? there wouldn’t be the same format issues involved that the external hard drives have?
    I guess that’d depend on if I end up getting a desktop or a Mac Mini. The people I’m sharing files with are 40 miles away, so that was the reason I was thinking external hard drive.
    Josh
  • 13 Create COW Profile Image
    13
    April 11, 2007 at 1:55 am
    you cant network a windows computer through firewire. And even if you could you said they are 40 miles apart. How big are the files you are sending.
    Check out http://www.yousendit.com
  • Tony! Hulette
    April 13, 2007 at 7:42 pm
    MacDrive from Mediafour is the best solution I’ve found (and its easy). Just install it on the PCs and format your drives for the Mac.
    https://www.mediafour.com/products/macdrive/
    They been making this product for along time and I know many people are very happy with it.
    Tony!
  • Brad Pemberton
    April 17, 2007 at 7:20 pm
    [zrb123] ”
    you cant network a windows computer through firewire.”
    Windows XP and Mac OS X (10.3 and 10.4) both support IP over firewire. That said you can get a possible dedicated 400 or 800 megabit connection using simple file sharing from the Mac (crank up Windows sharing in the Sharing Pref. pane.)
    BTW – FireWire 800 has a distance limitation of 300 feet.
