Activity Forums Apple Final Cut Pro Legacy format for pc viewing
  • format for pc viewing
    Posted by Adam Beasley on March 5, 2010 at 4:05 pm
    Hi Guys,
    I have about 50gb of XDCAM HD rushes, ingested with FCP which the client wants to view on their PC. (I do not have the bpav folders)
    I have experimented with full res h264.movs on several PCs in both QT and VLC but am getting slightly choppy playback.
    I need/want to deliver it in as high quality as possible but primarily it needs to play well!
    Any suggestions as to the best codec/container to use to achieve this? Even on a fairly slow PC..
    Thanks.
    A
    Adam Beasley replied 16 years, 6 months ago 2 Members · 2 Replies
  • Alan Smith
    March 5, 2010 at 6:20 pm
    If it is for preview purposes only, mpeg4 at 50% resolution, should work on a PC. We shoot HD XDCAM, convert to ProRes for edit and output to any format needed. PC is going to want mpeg4, wmv, avi, etc, which means encoding via Compressor . . .
    Alan Smith
    Media317
    Check out my blog – https://media317.com
  • Adam Beasley
    March 7, 2010 at 6:51 pm
    Thanks guys, went with .movs in the end at 50%, did a few tests, all seems to be fine. Going to send the full res ones too so if they are needed for anything other than viewing they have both anyway..
    A.
