Activity › Forums › Adobe Premiere Pro › format conversion from FCP to PP 5 Windows
  • format conversion from FCP to PP 5 Windows
    Posted by David Jahns on August 26, 2011 at 7:45 pm
    I’m being asked to transfer media that was ingested in FCP, and now to deliver it to an amateur Premiere Pro Windows user for editing. (I know very little about Premiere, and even less about Windows – sorry!)
    The other editor is requesting DVDs of the raw footage, so I’m guessing he’s not terribly versed in HD and professional file based workflows. i’m trying to help out, and keep things at highest quality through the pipeline.
    Original format is P2, DVCPro 720p24. I do not have access to the raw files anymore – they have been ingested into FCP, so there are now DVCPro Quicktimes.
    As I understand it, these will not work on Premiere on Windows, correct? We could convert everything to ProRes, if he’d be capable of installing the ProRes codec & QT Player. That would work, right?
    If not, is there a Windows friendly format/codec I could convert to (using a Mac & Adobe Media Encoder)? I don’t see AVI as an option – MPEG?
    Any help greatly appreciated.
    David Jahns
    Joint Editorial
    Portland, OR
    Todd Kopriva replied 15 years, 1 month ago 3 Members · 4 Replies
  • Todd Kopriva
    August 27, 2011 at 12:17 am
    I don’t know why you think that. Premiere Pro on Windows can read QuickTime movies just fine.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Chris Tompkins
    August 27, 2011 at 11:36 am
    Give the editor the RAW P2 Files on a Disc.
    And an xml if needed.
    Chris Tompkins
    Video Atlanta LLC
  • David Jahns
    September 1, 2011 at 4:06 pm
    Todd – I know PP can read Quicktimes, but I read in multiple places that it can’t read DVCPro Quicktimes that were generated during FCP Log & Transfer – some strange codec or wrapper issue. Not sure if that is really the case or not, which is why I was posting here for confirmation.
    Chris – I do not have access to the raw P2’s any more – only the FCP generated QT’s.
    Turns out i was able to talk directly to the PP Windows editor, and we settled on HD MPEG-2s – not ideal from my perspective, but certainly better than burning everything to a DVD.
    With the demise of FCP, I’m eager to learn more about Premiere, so thanks for the help!
    Dave
    David Jahns
    Joint Editorial
    Portland, OR
  • Todd Kopriva
    September 1, 2011 at 4:55 pm
    I’m not aware of such a problem.
    I do know of a related issue: If you use the AIC (Apple Intermediate Codec) in a QuickTime movie, then you can have a problem, because that codec isn’t available to other applications. Perhaps that’s what you heard.
