Activity › Forums › Adobe Premiere Pro › Format an External Hard Drive to use on MAC and PC
Posted by Frank Giardina on September 24, 2012 at 4:21 pmHi…
I recently switched over to CS6 (Adobe Cloud)and do the bulk of my editing on a MAC. I’d like to also work on my laptop PC in doing same day edits, then finish the rest of the project on a MAC. I’ve done a search and I see it is possible to partition a hard drive so I can share it. I’ve seen read/write restrictions and that has me worried, as I would have to play out file to play on a HD projector, then at a later date finish the same project on a MAC.
I could use some advise.
Best Regards
Frank Giardina
17 Video ProductionJim Miesner replied 13 years, 2 months ago 8 Members · 26 Replies -
Chris Tompkins
September 24, 2012 at 4:34 pmIf you format the drive FAT32 or eXFat, both WIN and MAC can read it just fine.
Chris Tompkins
Video Atlanta LLC -
Joseph W. bourke
September 24, 2012 at 4:38 pmFrank –
Here’s a good article on the process:
https://www.pcworld.com/article/250431/how_to_share_an_external_drive_between_a_mac_and_a_pc.htmlI’ve also read that the Seagate GoFlex drives are Mac and PC compatible out of the box, although I have not tried them. If you’re doing the bulk of your editing on the Mac, as you say, you may want to look at a couple of utilities which allow the PC to access the Mac file structure:
https://www.thedailybuggle.com/read-mac-drive-windows/
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Frank Giardina
September 24, 2012 at 4:47 pmThanks Chris… I’m gonna give exFAT a shot.
Frank Giardina
17 Video Production -
Frank Giardina
September 24, 2012 at 4:53 pmThanks Joe!! You guys are the best!!
Frank Giardina
Ron Pestes
September 24, 2012 at 4:58 pmAccording to the article I just read exFat only works with flash drives. What do you do with regular external hard drives unless you buy Macdrive?
ronpesteshdvideo.com
Apple Certified Master Pro FCS 2
Sony EX-3
MacBook Pro
Dell M6600
Adobe CS6 Production Premium -
Chris Borjis
September 24, 2012 at 10:17 pmNTFS works best for me, but requires some utility installation
or a paid app to make the mac able to write to the volume.FAT32 won’t allow files over 4gb in size.
Frank Giardina
September 24, 2012 at 11:46 pmChris… would that be individual files of 4gb? My projects contain clips totaling over 100gb, with some individual clips as large as 1.4gb.
YIKES! Maybe I should just get a MAC Laptop and eat MAC and Cheese for a while.
Frank Giardina
Tero Ahlfors
September 25, 2012 at 7:07 amJust use exFat. It allows bigger files and works with Windows and Mac. Just keep in mind that if you format the disk in Windows the cluster size can’t be over 1024.
Chris Borjis
September 25, 2012 at 4:10 pm[Frank Giardina] “would that be individual files of 4gb”
yes, fat32 won’t allow copying 4gb individual files or larger.
I have paragon NTFS Mac installed on all 4 of my systems here so
I can copy back to client NTFS formatted volumes if necessary. -
Frank Giardina
September 25, 2012 at 4:24 pmI figured I’d give this a try? If it doesn’t work, the drive will still be useful. I ordered a Seagate 2 TB USB 3.0 FreeAgent GoFlex Desk External Drive. The Paragon driver is a utility that is offered with the GoFlex family of external drives and enables MacOS to mount NTFS volumes (partitions), read from them, and write to them. In short, it makes the GoFlex drive usable on a Windows PC and on a Mac without any reformatting or data erasure or instability.
Frank Giardina
17 Video Production
