Activity › Forums › Adobe After Effects › Ford F-150 TV Spot
Ford F-150 TV Spot
Posted by Zach Rutledge on December 23, 2009 at 3:02 amI am trying to figure out a way to replicate what they did in this Ford F-150 commercial in After Effects CS3:
https://www.youtube.com/watch?v=xljekX8TCTY
Any ideas or can anyone point me in the right direction for a tutorial to help explain this technique?
Jeff Dobrow replied 16 years, 9 months ago 5 Members · 7 Replies -
Tracy Peterson
December 23, 2009 at 4:32 amWhich technique do you mean?
The color correction? The keying of original footage? The text animation? There is a lot going on here, what part intrigues you? There are a number of items adding to this lovely whole.
Tracy Peterson
http://www.onetwomany.com -
Aaron Shedlock
December 23, 2009 at 5:14 amI agree. Quite a lot going on. Lot’s of textures, cool camera moves, masks, keying, ramps, curves adjustments, etc etc. Excellent spot. Check out Andrew Kramer’s tutorial on his Sure Target plug-in as a way to quickly get those cool camera animations. Good place to start anyways. He also has some great bits about using textures, lighting, particles, etc, which would all be helpful in “re-creating” this spot.
Have fun learning how, that’s the best part.
Aaron
Programmer – an organism that turns coffee into software. ~Author Unknown
Michael Szalapski
December 23, 2009 at 6:03 amI agree with both previous posters.
The most important thing about these spots is planning. Lots and lots of planning. The techniques are mostly pretty basic; rotoscoping/keying, text, layer position animation, color correction, etc. Basic, but really well executed. It’s executed so well because of massive amounts of planning (coupled with very rather writing).
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Jeff Dobrow
December 23, 2009 at 3:59 pmThese are the ‘rant’ series of spots originated at Ringside for JWT.
No special techniques here……proficiency with AE ofcourse (obviously including camera control).Otherwise, everyone already said it.
Having just worked on one of these,…the best workflow is to design your type frames very loosely. Then rough out the camera motion for the type. Then go back and start filling in details.
The transitions are key. From side profile to overhead…etc..etc. -
Zach Rutledge
December 23, 2009 at 4:40 pmThanks for the feedback. Sorry about not being very clear in what I was asking. Actually knowing what steps were taken for the entire thing would have been great because, as everyone said, get spots!
I am mainly wanting to know how to animate the camera around the comp like they do with the different text and backgrounds. I would like to make a comp with many video “hubs” stationed around it and have the camera move around those hubs while the background and textures used in the background repeat. I have seen this done before but I am having a hard time trying to figure it out.
Jeff Dobrow
December 23, 2009 at 5:35 pmThere really isnt a magic workflow for this.
You cant just create a bunch of scenes in 3-space and then fly between them
You must pre-plan your moves and scenes…..then animate a rough camera move to go between them.
The subtle polish of the motion, use of mblur to shield bg transitions and…etc…etc.Specifically regarding the camera it just depends. Not all of it is 3D camera work at all. Moving your scenes around while the cam stays in place….in some instances moving your foreground scenes while your BG stays in place…etc..etc.
There is no specific ‘way’ to animate the entire spot. It simply requires planning and more planning….With regard to cam only: Parent cam to 3D null. Add seperate x,y,z animation transform preset to null. Animate the x,y,z transform effect and not the cam.
