Activity › Forums › AJA Video Systems › Force RGB in Color
  • Force RGB in Color
    Posted by Alan Okey on September 14, 2007 at 3:35 pm
    I recenty discovered that the Force RGB option in Apple’s Color is currently not functioning with Kona cards due to a bug in the Kona 4.0 driver. Force RGB offloads RGB>YCrCb conversion to the capture card to lighten the software processing load, which can potentially improve realtime playback performance.
    As a current Kona LHe owner and former Blackmagic Decklink owner, thus far I have found AJA to be superior with regard to support and documentation. is it likely that AJA will come out with a bug fix/driver update to address this issue in a timely manner?
    Walter Biscardi replied 19 years ago 2 Members · 1 Reply
