Activity Forums Adobe Premiere Pro Force render on CS5
  • Force render on CS5
    Posted by Dennis Rafn on May 13, 2010 at 11:39 am
    Hey
    If i import a complex AE comp into Premiere, and i am in a mercury setup – the AE comp is yellow. The comp is so complex that a realtime playback(in all fairness) is out of the question. But how to render it ? Is there a way to force render ?
    Ann Bens replied 16 years, 3 months ago 2 Members · 3 Replies
  • Ann Bens
    May 13, 2010 at 8:51 pm
    Under Sequence you will find: Render entire work area. Set your work area bar accordently.
  • Dennis Rafn
    May 13, 2010 at 11:17 pm
    Hi Ann
    Thanks, but i dont see how to render when its marked as YELLOW – not RED. So Premiere thinks it can handle it realtime, but this comp surely needs render.
  • Ann Bens
    May 14, 2010 at 7:00 pm
    Dit you set your workbar over the area you want to render and did you hit “Render Entire Work Bar” in the pulldownmenu under Sequence?
