Activity › Forums › Apple Final Cut Pro Legacy › Force FCP to add “.mov” extension to captured files?
  • Force FCP to add “.mov” extension to captured files?
    Posted by B. Rordin on July 7, 2006 at 11:53 am
    Is it possible to force FCP to add “.mov” extension to captured files? I need this because when I access the captured files form Combustion on my PC workstation I need to add “.mov” to each file and then reconnect the media from FCP and for big projects this can be a very slow process.
    Martin Baker replied 20 years, 2 months ago 2 Members · 3 Replies
  • Martin Baker
    July 7, 2006 at 1:37 pm
    It’s not possible to force this directly in FCP because of course Apple want you to encourage you to stay working in Mac applications 🙂
    However, there are numerous apps which do batch renaming on files so you don’t have to do it manually:
    https://tinyurl.com/lb34z
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! BigTIme – resizable timecode display for FCP
  • B. Rordin
    July 7, 2006 at 1:48 pm
    Thanks! Is there a quick way to relink the renamed media files in FCP or it should be done manually?
  • Martin Baker
    July 7, 2006 at 1:52 pm
    Unfortunately you’d have to do it manually since the filenames have changed – FCP considers a file named “MyCapture” to be different from a file named “MyCapture.mov”
    Martin
