Activity › Forums › DaVinci Resolve › Force Conform from Folders
  • Force Conform from Folders
    Posted by Rick Turners on March 6, 2012 at 11:58 am
    I’m doing a stereo project,
    When I separate the files to Left and Right, and bring in the L and R EDLs, then tell it to conform from the left and right folder respectively, some of the files are still grabbing from the wrong eye. (even though its in the left eye folder when the only box I checked is the right eye folder)
    Is Force conform supposed to keep the files outside of the folder selected from being able to be conformed?
    Anish Prithviraj replied 14 years, 6 months ago 3 Members · 3 Replies
  • Peter Chamberlain
    March 7, 2012 at 12:44 am
    The force conform can only act on the folders you select so no right eye folder files should be in the left if you only select left. Could the source shots be accidentally in the wrong folder. Use Swap Eye to fix that.
    Peter
  • Rick Turners
    March 7, 2012 at 9:10 am
    Thats the thing, I just did it again, for whatever reason it is grabbing the file from the left eye folder even though I’ve told it to go with the right eye.
    When I locate in media pool it shows me that its grabbing from Left.
    It’s only for a couple of dozen or so shots, but I cant figure out why it would do this.
  • Anish Prithviraj
    March 7, 2012 at 10:55 am
    Could you send an export of the project (with EDLs) to davincihelp (at) blackmagic-design.com?
    Also, what version and platform are you running Resolve on?
