Activity Forums Adobe After Effects Expressions force comp to play from the beginning with every checkbox key?
  • Dan Ebberts
    January 24, 2011 at 4:34 pm
    Try this:
    chkBx = effect("Checkbox Control")("Checkbox");
    if (chkBx.value == 0){
    0
    }else if (chkBx.numKeys == 0){
    time
    }else{
    n = chkBx.nearestKey(time).index;
    if (chkBx.key(n).time > time) n--;
    time - chkBx.key(n).time;
    Dan
  • Taras Kosmachuk
    January 24, 2011 at 7:46 pm
    Hey Dan, it’s working great! Many thanks to you!!!!!
  • Cris Gundermann
    October 12, 2013 at 12:35 pm
    hi dan,
    thanks for this script (and for all the others i could find here)!
    i’m trying to combine this one with another script by you but i can’t get it to work.
    it only works with the last condition.
    i want a comp to play at random intervals but also want it to play when i activate it manually via checkbox.
    i guess it must have sth to do with how the keyframes are held,
    but when i remove the first part of the second condition and leave it like this:
    if (chkBx.value == 1){
    if (chkBx.key(n).time > time) n–;
    time – chkBx.key(n).time;
    … nothing will change…
    i’m not that much into expressions, so i’d be thankful if you could help me out a bit!
    thanks in advance,
    -cris
    //if activated, play comp at random intervals.
    minDur = 1;
    maxDur = 2;
    randChkBx = comp("xxx").layer("xx").effect("playRandom")("Kontrollkästchen");
    if (randChkBx.value == 1){
    seedRandom(index,true);
    t0 = inPoint + random(maxDur);
    t1 = t0 + random(minDur,maxDur);
    while(t1 < time){
    t0 = t1;
    t = time - t0;
    } else {
    value
    //if activated, play comp, else hold on 0.
    chkBx = comp("xxx").layer("xx").effect("playNow")("Kontrollkästchen");
    0
    time
    }else{
  • Dan Ebberts
    October 12, 2013 at 4:53 pm
    I think you need to nest one of the expressions inside the other. If you wanted the playNow checkbox to have priority, you would do something like this (not tested):
    minDur = 1;
    maxDur = 2;
    while(t1 < time){
    t0 = t1;
    t = time - t0;
    } else {
    value
    time
    }else{
    Dan
  • Cris Gundermann
    December 11, 2013 at 10:43 am
    hi,
    i totally forgot to reply and thank you.
    with your help i could achieve what i was aiming for.
    all the best
