Activity Forums Apple Final Cut Pro Legacy force capture issues
  • force capture issues
    Posted by Smith Glover on April 1, 2009 at 9:12 pm
    hello-
    i have a bad source tape that i need to capture. it has time code, which seems to work just fine, actually- but the tape has major audio and video glitches. i switched to “con-controllable device” in the capture window (thank you- this forum helped me to do this and it worked last time)- but capture still aborts every 30 seconds to 2 minutes- with the error of: “capture encountered a problem reading the data on your source tape. this could be due to a problem with the tape . . . ”
    any thoughts on how i can force FCP to capture?
    thank you for your help.
    smith
    Smith Glover replied 17 years, 5 months ago 3 Members · 3 Replies
  • Shane Ross
    April 1, 2009 at 9:59 pm
    DUb this tape to another tape. Capture that other tape.
    Shane
  • Joel Peregrine
    April 2, 2009 at 1:29 am
    Try this app to capture the tape:
    https://www.bigmugsoftware.com/capture/
    It has a trial period. Works where nothing else will – its not constrained by QuickTime, so in addition to capturing right over timecode breaks you can capture more than one source at a time. The synch of the capture will be off if there is timecode weirdness, but you’ll get it captured and can synch it up on the timeline…
  • Smith Glover
    April 2, 2009 at 8:48 am
    Joel,
    Wow- that program is amazing. Thank you-worked like a charm.
    Smith
