Activity › Forums › Adobe After Effects › For some odd reason, I cannot open a AE CS6 project file in CS5
Posted by Mordy Rapp on June 13, 2012 at 9:38 amThis is insane.
Ive looked all over the internet and there is no info on this compatibility issue.
Any ideas?
Vinit Béléy replied 12 years, 11 months ago 5 Members · 4 Replies -
Walter Soyka
June 13, 2012 at 2:09 pmAE projects are forwards-compatible for several generations, but they are not backwards-compatible.
AE CS6 has an option to save a CS5.5 project, and CS5.5 has the option to save a CS5 project. These are the only exceptions to the rule above.
One other option you could try is pt_OpenSesame [link].
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
John Cuevas
June 13, 2012 at 2:13 pmAdobe files are not backwards compatible.
If you want to open it in CS5, you would need to use the “Save a copy as CS5.5” Then you would need a copy of CS5.5, open the project and “Save a copy as CS5”
Any effects that aren’t in the CS5 version would be listed as missing, but when you go forward again, they would be return with the original parmaters used, ie..warp stabilizer wouldn’t show up in CS5(missing), but if saved the CS5 project and opened it up later in CS6 it would return it would return with the original settings you used in the initial project.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Chad Ridgeway
December 28, 2012 at 2:25 pmClassy move Adobe… update yearly with incremental improvements and force everyone to keep shelling out.
