Activity › Forums › Apple Final Cut Pro Legacy › For Rafael-steps to MP4
  • Rafael Amador
    August 7, 2013 at 1:29 pm
    That’s with QT Player.
    Just open the Export window (Cmd-E), and instead of selecting “Movie to Quick Time”, hit the “Options” button, and select “Movie to MPEG-4”.
    In the pict you can see the QT Export window below the “Mpeg-4 Export Settings” window.
    rafael
  • Alexander Kallas
    August 8, 2013 at 12:01 pm
    Thanks Rafael, do you have any settings for a PAL video please?
    Cheers
    Alexander
  • Rafael Amador
    August 8, 2013 at 4:04 pm
    Well, frame rate: 25fps.
    The rest depending of the file size/quality you want.
    Key-frames always AUTO, and down in the Video Options: Multipass.
    rafael
  • Alexander Kallas
    August 8, 2013 at 10:29 pm
    Thank you,
    of course, but I was thinking about the correct aspect ratio.
    Which dimensions will be correct for PAL?
    Cheers
    Alexander
  • Rafael Amador
    August 9, 2013 at 1:35 am
    If you want to make a web video from a PAL movie:
    – If the stuff is PAL 4×3: 768×576
    – If 16×9: 1024×576.
    rafael
