Activity › Forums › Apple Final Cut Pro Legacy › for Matt re: the strobing/double image graphic problem
  • for Matt re: the strobing/double image graphic problem
    Posted by Kent Beeson on November 9, 2005 at 6:19 pm
    Extended the graphic from 1:12 sec to 3 seconds and it has NO problems, so it is the length of the shot that is the problem…will have to re arrange things in order for this to work as needed at 1:12 sec. Thanks for the advice.
    KB
    Kent Beeson replied 20 years, 10 months ago 3 Members · 13 Replies
  • 13 Replies
  • Bouncing Account needs new email address
    November 9, 2005 at 6:42 pm
    Glad you figured it out.
    Tricky stuff this, this video motion 🙂
  • David Bogie
    November 9, 2005 at 8:43 pm
    Sorry, wasn’t watching the original thread. So this was the result of having a non-integer speed value that produced an odd number of frames?
    bogiesan
  • Kent Beeson
    November 9, 2005 at 9:23 pm
    Hi:
    Actually, can you believe it, it did look good on my TV out of FCP 4.5, but when I made an MPEG 2 (which I need ultimately) test of the section, the same double image is still there! I posted a good result too soon. If I could send a screen grab of the graphic with its problem to someone to look at maybe this would help identify the issue.
    KB
  • Kent Beeson
    November 9, 2005 at 9:29 pm
    original post was Nov 4 and 5
  • Kent Beeson
    November 9, 2005 at 10:47 pm
    https://www.odmawireless.net/beeson/Picture1.pdf
    (screen grab from DVD SP 2 simulator)
    https://www.odmawireless.net/beeson/Picture2.pd
    (screen grab from m2v)
    just checked from DVD player (panasonic DMR-E50) to TV monitor, same color bleeds/bad double image as shown in pics above.
    KB
    [Kent Beeson] “If I could send a screen grab of the graphic with its problem to someone to look at maybe this would help identify the issue.”
    You have been BEGGING (!) to send someone an image of this problem since we started this 😉
    (I don’t know what you think we can SEE if you send it, but no matter.)
    If you want, you could POST a link to this image, I guess we can LOOK at it and maybe it will enlighten us.
    To post it, just go to-
    http://www.photobucket.com
    Just sign up…its FREE!
    You can then uplink as many images as you want to THEM, then post back here with the LINK to the images.
    I, as yet, don’t fully understand what the PROBLEM is, but a seeing a STILL of it may or may not help.
    Sorry.
    November 9, 2005 at 11:05 pm
    This looks like a NORMAL still-frame taken from a video when something is in motion.
    Is this image NOT moving at this point?
  • Kent Beeson
    November 9, 2005 at 11:13 pm
    The screen grabs were in still mode, but even on the TV from a DVD player – as it’s playing – this color bleeding and double image appears. Now if this is simply the nature of the beast, then I’ll just have to live with it.
    KB
    November 10, 2005 at 12:25 am
    [Kent Beeson] “The screen grabs were in still mode, but even on the TV from a DVD player – as it’s playing – this color bleeding and double image appears. Now if this is simply the nature of the beast, then I’ll just have to live with it.”
    I still do not understand what you are doing with these images.
    If they are MOVING, they will always “flicker” in the paused still-frame.
    If they are NOT moving, they should NOT “flicker” in the paused still-frame.
    If they are on the key-frame NEXT to the key-frame when they BEGIN to move, they will always “flicker” in the paused still-frame.
    As to “color bleeding” I simply do not see any of what I call “bleeding” in either picture.
    My suggestion is to try this:
    Do not animate the logo on this experiment.
    Place a new still-frame of the logo-frame “static” (just “sitting”) on the timeline and see if it “flickers”.
    If its OK, then we know its the motion that’s causing what you see as a problem.
    You could then choose to do a different KIND of motion for the logo (sideways, a zoom-OUT, or anything other than a full-screen vertical motion).
    Then, see if you like that better.
    And please post back here with further results.
    November 10, 2005 at 12:36 am
    OK, I just took Picture 2 into Photoshop and applied the Filter: Video > De-Interlace.
    It got rid of the flicker of the motion and allowed me to see where the gold color of the logo “ring” is riding above the rest of the image.
    It looks like that layer of color is out of “registration”with the rest of the image.
    If this is the “color bleeding” you’re talking about, then it looks like you have a faulty imported image (or the wrong KIND of image.)
    How was this image created?
    What kind of image is it? (.psd, .pct, .tif)
    How was it imported into FCP?
