Activity Forums Adobe After Effects Expressions for loop generating double digit numbers keeps putting more than single digit numbers on multiple lines
  • for loop generating double digit numbers keeps putting more than single digit numbers on multiple lines
    Posted by Ryan Fannon on February 6, 2014 at 6:10 pm
    I am trying to generate a list of of even numbers between 200 to 0 in a vertical type layer. The for loop I have created works, but when it’s spits out the numbers it places all numbers with more than one digit on multiple lines.
    For example
    200
    Looks like
    2
    0
    0
    Is there a way to force the numbers digits to be on one line?
    Here is my for loop placed in the source text
    x = "";
    for (var i=200;i>=0;i = i-2)
    x = x + i;
    text.sourceText = ""+ x +"";
    *EDIT
    Nevermind, I was able to figure it out. However, I ended up using a horizontal text layer.
    x = "";
    for (var i=12;i>=0;i = i-2)
    x = x + i + "r";
    text.sourceText = x;
    Declan Smith replied 12 years, 7 months ago 2 Members · 1 Reply
  • Declan Smith
    February 6, 2014 at 6:29 pm
    Ist, use normal horizontal text, then use this expression. The “\n” appends a newline at the end of each number
    x = "";
    x+=i+"\n";
    text.sourceText=x;
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
