Activity › Forums › Adobe Encore DVD › for inquiry
for inquiry
Posted by John Geagea on December 10, 2013 at 2:53 amHi.
I’m using adobe cs5.5 and i want to know which setting should choose to prepare the right project at encore cs5.1 to burn it for dual layer 8.5mbthank you for the help
John Geagea replied 12 years, 9 months ago 2 Members · 4 Replies -
Jeff Pulera
December 10, 2013 at 3:06 pmHi John,
What is the source format/sequence setting in Premiere? What is the length of the project to be burned?
Jeff Pulera
Safe Harbor Computers -
Jeff Pulera
December 11, 2013 at 2:47 pmDVD is always MPEG-2, was asking what footage you were starting with as that can make a difference in workflow. I would recommend against dual-layer DVD, too many headaches/compatibility issues. I’ve been putting 2 hours or more on 4.7GB DVDs since the technology became available and have never had a client complaint about compression, just use VBR 2-Pass. Set Target to 4.5 for 2 hours.
Jeff Pulera
John Geagea
December 12, 2013 at 2:22 amThank you so much for your advise and i will try to use the 4,7mb as well.
