  • Posted by batnyam batsaikhan on November 15, 2021 at 3:02 am
    Dear All
    I need your help.
    Please check below expression
    for (var k=0; k<21; k++);
    if(footage(“daily-by-location.json”).dataValue([1,k,8])==”618f344d1cb3e06d152fd4b3″){
    footage(“daily-by-location.json”).dataValue([1,k,4])}else{“No Match”}
    the json file located in harddrive.
    the result is false, but i know that “618f344d1cb3e06d152fd4b3” exist.
    the var k does not loop.
    if the var k is defined, for example “1” the expression would show the desired result.
    Is my expression correct or not?
    Dan Ebberts
    replied 4 years, 10 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    November 15, 2021 at 1:48 pm
    I haven’t tested this, but I think you’d want to structure it more like this:
    val = "No Match";
    for (var k=0; k<21; k++){
    if(footage("daily-by-location.json").dataValue([1,k,8])=="618f344d1cb3e06d152fd4b3″){
    val = footage("daily-by-location.json").dataValue([1,k,4]);
    break;
    val
